74 w/5 series window motors help
so this is the 74 w "5" plugs at the switch
and the breaker buttons under ther dash that just cuts power to the switch
so the 5 series motors have two wires
reverse polarity and they go up and down when reversed
but the 5 prong switch only provides 2 active prongs when pressed
only one up and one down with one common
how does the motor work with the switch as
when you press one side you no longer hit the other side of the motor
so do the 4 prong switches reverse polarity
