• Tapatalk is being removed immediately. There are security issues and there is no justification for having it anymore. I apolgize to those die-hard Tapatalk users but you'll need to start using the forums mobile version instead.
Anyone know which 5speed is in 633csi
bossrobot
berkeley ca.
I am looking at a 1982 633csi that is for sale. It is a 5 speed and the owner says it has a replacement 3.5l with low miles. I contacted them for more details.
Is this a good engine/ trans swap for my E9?
Other parts interchange?
Is this a good engine swap
sfdon
sfbay area
At least get a pic of the bellhousing and intake side of the block
Imagine if a m30b34 low compression engine with a 260 tranny Shows up........
bossrobot
berkeley ca.
Thanks for the tips !
I am working a lot now (no days off this week) and might miss it as its 3 hours away form me.
mr bump
nottingham, UK
I’m sure 1979 was the last year the 6 series used a Speedo cable drive gearbox, but if your lucky, the hole for an E9 speedo cable my just be blanked off.
I used the dogleg 5 speed box, cross member, slave and master cylinders, clutch, pedal ect and the side loading LSD from a 79 635 csi for my E9, diff went straight in no problems, had to do some work for the box as I converted mine from auto to manual. It still runs the 3.09 ratio compared to the 3.68 auto ratio, I thought it would be a bit sluggish, but the 3.09 is perfect.
Bert Poliakoff
Scottsdale, AZ
260 does not 262 does not. Why do you think it is a 260? Was it just an engine swap or a complete drive train swap?/was the car a manual to begin with? On a 6 series, if the speedo is not mechanical, it will say electric just above the VDO under the odometer reset If the car is local, why not just look under it and see if there is a cable coming out of the lower right rear side of the trans
Mot27cars
Elkhart, IN
Oops. This is an 83 from a 533i
HB Chris
Huntington Beach, CA
"The 265 Getrag was first used in the 1980 BMW 528i and continued to be used in all 5/ 6/ & 7 series BMW models up to and including 1982. In 1982 the BMW 325e had the Getrag 260 and the following year all BMW 6 cylinder models got the 260 up until 1985. These early 260 transmissions were a bit problematic. In 1985 BMW made an unusual move, they switched back to the Getrag 265 in the 5/ 6/ & 7 series. All, 1986 models got a revised 260 Getrag."
Don will correct me but (edit: 1982) was last year with mechanical speedo drive.
Bert Poliakoff
Scottsdale, AZ
Chris just for kicks check out "84 633 on real oem and it will show exploded parts view of trans parts with speedo drive, if I am correct
HB Chris
My quotes were from Metric Mechanic. In RealOEM if you select a 1983 build date 633CSi there is no part number, they didn’t change diagrams by year, and it’s a 260 trans. That is why the mechanical drive 265/6 is so rare now.
it does appear in a 1982 CSi though as a 265/6 with the drive.
sfdon
sfbay area
And to prove how good the 265/6 was- it was installed in all those M3 cars from ‘87 to ‘91
Markos
Parts Hoarder
Staff member
Seattle, WA
Don and I bought a 1982 528e with the 265 a few years ago. I wasn’t expecting it to be the case but it did have an electronic speedo.
