Are theC Pillar Vents on 2500 Functional?
CSteve
Bucks County, PA
Looking at the photos of a 2500 I do not see anything but the vents on the C pillars. Ae they functional or vented somewhere else?
I was driving my 71 E3 2800 this weekend and felt air coming out of those openings above the windshield
The vents is the only logical path for the air to travel through
Then I found this:
@Ezz : That's an interesting path inside the unibody chassis construction.. it makes me wonder.. does a complete E3 interior fully block or significantly reduce the airflow you've discovered? I pose that question because your E3 interior is in the process of being rebuilt. I have no reason to believe this chassis pathway was intentionally designed for galvinization / rustproof dipping processes (which did not become common on vehicles until the mid / late 70s).
Ok I blocked those vent openings today and drove it
air still came out from the same place
Assuming you covered the exterior c-pillar vent areas (where the horizontal inset mounts), this airflow path must extend deeper into the chassis somewhere near the rear wheels.. because the path appears blocked in your photo of the exterior c-pillar vent.
Perhaps @HB Chris can shed some light on this... ?
I’ll take some pics of mine tomorrow. It’s torn apart and you can see where the vents go back there
I know about the rear vents. I was just curious about the c pillar vents if they really were venting or not. It seems that they are not especially when headliner and insulation is in place.
Ok, so I just blew air through mine and yes, the very top of the vents connect to the upper inside of the car..in pics. *Edit: with headliner in place, it would be a smaller amount, being the opening is behind the headliner (not covered by foam), but I imagine still useful for things like defrost, etc..
  • Like
Reactions: Ezz
