Bavaria flexible dash hose
Discussion in 'E3 General Discussion' started by Sooner, Jan 14, 2019.
  1. Sooner
    Sooner Active Member Site Donor $
    639
    56
    28
    Farmington, NM
    Does anyone know a source of the fiberboard flex hose under the dash of the Bavaria. Replacing my dash, and the old stuff just crumbled, thank you
  2. mosearch
    mosearch Member
    90
    13
    8
    Mill Valley, CA
  3. Sooner
    639
    56
    28
    Farmington, NM
    After visiting with Carl Nelson, definitely no longer available, but hint to check VW
    Mid America Motorworks part #321-691 fits perfectly, and only $7.99
  4. Paul Wegweiser
    Paul Wegweiser New Member
    17
    16
    3
    Pittsburgh, Pennsylvania
    I recall on many air cooled Porsche and VW sites that the foil reinforced hose (if you really want to refer to that foil as "reinforcing" material - it's still pretty fragile) :) Was used and is available in at least 2 or 3 diameters. Perhaps you can find a match up through Stoddard or elsewhere. Try companies like "McMaster-Carr" and "Aircraft Spruce and Specialty" also. You can spend HOURS cruising through those two sites looking at wondrous mechanical/linkage/hardware/cable/tubing things you never knew you needed! Both are pretty fascinating sources for ideas, if you're a nerd like me.
    Hope this Helps!
    Paul Wegweiser
    Lead Classic Specialist
    Maximillian Importing Co
    classicbmwparts@gmail.com
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
