Best Sheet Metal Sources
JetDexter
Newport Beach, CA
Hi guys,
My metalwork is going well, and we have fabricated a lot of what we need. But of the metal sections I have purchased, not a one actually fit like the factory piece. It is as if they looked at a section, and fabricated it from memory :) This is from a couple of different sources, for floors, rockers, etc.
So I wanted to get any opinions on the rest of the items I need. I still need Door Skins, Inner front fender pieces, and a drivers rear wheel arch (which I could just cut out of a donor car I have available).
Any input would be appreciated. Thanks guys!
Paul
Markos
Seattle, WA
Hi Paul,
Do you need the whole inner fender or just the tops?
For the rear arch, keep in mind that the fender is spot welded to the wheel well with 15-20 spot welds. Your used fender arch kind of looks like swiss cheese once removed. It is helpful if you can find the exact location of the spot weld. To find the spots, use a die grinder with a scratchy pad, not an angle grinder with a flap disk. The flap disk is too abrasive and will obscure your spot welds.
JetDexter
Newport Beach, CA
For the fronts, it is mostly the top pieces, but those vertical sections that lead to the cabin are shot. We could fabricate what is needed, but certainly want to see what is available first . Here's a couple of photos. The second photo is mostly for fun because it shows what may be the most creative use of anything BUT steel and welding to do a repair: Rebar, Fiberglass, Duct Tape, Something that came out of a caulking gun and Gauze (which is probably just the duct tape lining, but it is funnier to think that they used Gauze).
I would love to go to the expense to replace the front fenders, but the expense of even moderately bad replacements is so high, that we are planning to just patch them with a dozen patches. If anyone knows of a couple of donors, that would be awesome.
Markos, that is good to know about the arches- will do.
autokunst
Milwaukee, WI
It kind of looks like they used rattan to back the patch work - was this car from the tropics? :cool:
Sorry - not poking fun, just enjoying the journey through your pics. I've discovered that my car is much heavier than it should be, and I am starting to wonder if there is some concrete buried between the sheet metal... The rebar would be right at home as reinforcement if so.
m5bb
Peachtree Corners, GA
View attachment 60641 View attachment 60642
Looks familiar.
My RF has a bunch of fiberglass and filler in the top. Yuck!
Honolulu
Honolulu Hawaii
The woven product, described as "rebar" by some, but correctly identified as fiberglass by m5bb/Gary Beck above (good on ya, Gary). More specifically, it's known to those who use it as "woven roving" meaning that the actual fibers in a strand are parallel rather than twisted or otherwise arranged.
"Rebar" is a short term for "reinforcing bar" the steel rods used in concrete construction to provide tensile strength to the finished product. That material generally starts at 1/4" diameter and can go as big as 1.5" diameter.
Let's not call it "rebar" which is steel, when it is woven roving in reality.
autokunst
Milwaukee, WI
Charlie, yes the generic fiberglass in the pic looks like woven roving. But I think Jay was referring to the steel rebar that is also shown in the pic.
rsporsche
Atlanta, GA
better look deeper, might find Hoffa buried in there (in pieces)
JetDexter
Newport Beach, CA
Yeah- and there are a few short pieces of rebar running perpendicular to the long one- probably tied together with bailing wire just like in concrete work:). We haven’t dug deep enough to find out[emoji20]
JetDexter
Newport Beach, CA
Hi guys, just a bump to see if anyone has thoughts on suppliers for this metal. CSI, Inc in Pomona can supply everything. Ben over there has been a good and fair guy so far, but I wasn't happy with the rockers I got from him.
I hate to spend a over two thousand $ on the 5 pieces each side that he is recommending, only to not have them line up properly :)
Thanks again
autokunst
Milwaukee, WI
My amateur and not-fully-tested opinion is that none of the sheet metal available (I'll even include BMW in this statement) will perfectly fit our cars. They (the cars) have been twisted, racked, and stretched for the past 45 years or so and they are, frankly, not the same shape that they were off the line. I know there are bead aligment issues with the floor panels from some (if not all) of the sources. Some on the forum have manipulated these panels to re-align. There are stampings missing (that some have pressed/stamped in). All super impressive work. I plan/hope to do some if these same fabrication tweaks myself when the time comes. And I am of the opinion that it will be easier to modify a panel that is close rather than fabricate some of these shapes from scratch. So far, I have been amassing metal from WN and BMW. I'll document what I find when I get to that point.
HB Chris
Huntington Beach, CA
Thanks again
Ask him whose panels they are. He resells BMW parts but may have these made elsewhere or he is reselling W&N panels. He doesn’t make them himself that’s for sure.
JayWltrs
Oklahoma City
Time spent searching the threads will be well spent cost/time savings & enjoyment. Posts and threads detail the benefits & fit of the different sources and some excellent photos of first-hand experience among the restoration threads, including some truly amazing metal work from some of these folks, including detailed approaches to work around or fine-tune fitment issues. Seriously, some of these folks have mad skills or experience and some take you through their mistakes so you can avoid them.
There are specific suggestions on what parts to get from W&N and what to get from other sources--e.g., some floor panels you get from W&N and some from the "polish guys," and the threads explain/show why. [Edit: https://e9coupe.com/forum/threads/w-n-front-floor-panels.29773/#post-238511 ] Some just buy sheet metal and go at it. In addition to W&N, some of the sources I've bookmarked from these discussions, include:
http://sklep.manufaktura-workshop.pl/index.php/czesci/bmw/
http://www.alfaparts.net/bmwcs.htm
https://www.jaymic.com/2-5cs-to-3-0csl/body-chassis-parts/body-repair-panels.html
https://www.bmw-oldtimerteile.de/in...ieteile-dichtungen-anbauteile-4/results,21-40
You can figure out everything you need and bundle for shipping, but it seems more likely to get hit with duty. And it seems there's no clear answer as to what the threshold is for what they tag or let through.
Really excited to see this work out for you.
Edit again: For the sporty option: http://zaprace.com/
JetDexter
Newport Beach, CA
Thanks so much Jay. Yes, I try to dig through those threads and grab bits of wisdom here and there, but as you mention, it seems that there really isn't a "best" approach or source universally. Just like the parts I have bought so far, they ALL required a pretty major amount of modification, and that's just the way it is. I don't necessarily subscribe to the view that it is because our cars have sagged, bent and so forth- as these parts seem SO different from the original (when comparing to a rare good and original portion of my car that is).
Regardless, this is some good help as I continue to make these decisions!
Thanks guys
Gransin
Vasa, Finland
Thanks guys
I bought most (all?) of the metal parts that I needed from W&N, and I can't say they needed significant modifications to fit, some of them was even a very good fit.
Then again, we all have different opinions about what's good enough and not, so while I think they were/are good, the next guy might not.
And I'm pretty sure there are considerable differences from one coupe to the other, so what fits on the first might not fit as good on the next, and who really knows how much difference there might be between different production batches of the replacement metal.
