nobrakese28
- Messages
- 229
- Reaction score
- 12
Hi. I thought I would document the 5SPD manual conversion I am performing on my 1971 BMW 2800CS. This is intended as a reference only, please only work on you vehicle if you are confident and able, I assume no responsibility for anyones actions.
BMW Parts:
Transmission: Getrag 265 5SPD
Transmission Mounting Bracket: 23711175731
Transmission Mounts:
Transmission Tower Shift Mounts:
Shifter Mounting Plate:
E28 M5 Guibo: 30mm thick: 26117511454
Driveshaft: E9 2800CS Auto Transmission Driveshaft lengthened 1.6 inches (could possibly be a 1978 530i driveshaft, they may be the same)
Pedal Box: Pedals from any manual, use what ever pedal box you have in your car.
Clutch Line: La Jolla Independent
Clutch Slave:
Clutch Master:
Clutch Kit: E28 533i/535i
Rear Main Seal:
Rear Main Seal Housing Gasket:
Starter: (good idea to replace with the E30 M3 if you have a stock unit, the E30 M3 is much more compact and easy to install)
Exhaust Manifold Gaskets:
Fasteners:
Flywheel bolts:
Pressure Plate Bolts:
1) The first thing I did was securely place the CS on my Mohawk, I took a look at the car and verified that I wanted to start the job. This isn't a quick 8 hour job, there are a lot of parts that need to removed and replaced. Then I removed the battery from the engine bay. This is important as you will be removing the starter.
1a) The first thing I did was remove the center portion of the exhaust, watch your knuckles as the bolts are likely rusty. There is a 90% chance that the exhaust will not slip off from the slip fit, if it doesn't. First remove the 6 bolts from the flanges, then have an assistant support the muffler while you remove the 3 bolts holding the rubber hangers, don't balance it over your shoulder's like I did...
2) Remove down pipes, 6 bolts.
See photos.
BMW Parts:
Clutch Slave:
Clutch Master:
Rear Main Seal:
Fasteners:
Flywheel bolts:
See photos.
