Did the wheel have tires. If the aluminum is touching the rubber most certainly will.
No tires mounted yet to the rims yet, but I have a set of used 225 50 16 tires that came off my Mustang for test fit. Pretty sure the tires would fit with the 5mm spacer in there up front, though there might be a bit rubbing with tire deflection on the the strut housing, as well the front inner fender lip. I'd feel safer running the 215 55 16 tire size all around, with the front fender lips rolled. The main thing with the 215 55 16 tire size will help keep the tire from deflecting on the rim, effectively stretching the tire across the rim width, and make the car feel tighter in road response, as well 55 profile will help with ride quality...
I’m not sire about actual width. Visibly you have about an inch of extra fender clearance in the rear. You also have quite a bit of inner fender clearance. Enough to run 9” wheels.
