C Cyrano Active Member Messages 52 Reaction score 50 Location France May 15, 2025 #41 That sounds good! Thanks for the tips Fritzie! By the way, anyone knows why the center plugs were removed from the rocket arm axle and when it happened?
Fritzie Well-Known Member Site Donor Messages 298 Reaction score 247 Location The Netherlands May 15, 2025 #42 Cyrano said: That sounds good! Thanks for the tips Fritzie! By the way, anyone knows why the center plugs were removed from the rocket arm axle and when it happened? Click to expand... See also Post in thread 'Cracked head. Need a replacement' https://e9coupe.com/forum/threads/cracked-head-need-a-replacement.46677/post-411978
ScottAndrews Well-Known Member Site Donor $ Messages 1,587 Reaction score 1,006 Location Petaluma, CA May 15, 2025 #43 This is an interesting thread. Would be very useful to classify things a bit. For example: Evolution: Changes from earliest to latest... and why Interchangeability: What heads work with which blocks, which intakes, cams, etc Specs: Valve sizes, combustion chamber volumes, etc...
sfdon Well-Known Member Site Donor $ Site Donor $$ Messages 10,009 Reaction score 6,833 Location sfbay area May 15, 2025 #44 The plugs had a bad habit of backing out so changes were made. I have NOS plugs if anyone needs them!
L Larry Louton Well-Known Member Site Donor $$ Messages 196 Reaction score 96 Location Venice Florida Sep 18, 2025 #45 Got those condom style seal protector. Thank you. Larry Louton
