I splurged and bought a used Blue Point carb adjuster screwdriver. It is a flexible 1/4 extension in a tube with a twist knob on one end and a 1/4” square drive on the other end. You add a 1/4 square to hex adapter ($4) so you can use any hex bit.
This makes getting to the various Weber DG screws trivial. Not needed for DCOE’s. Unsure if it’s helpful with Zeniths.
Highly recommended if you need to play around with Weber downdrafts. I paid $20 for it.
