Center Console Blank Renew...kinda
bavbob
Boston, Ma
Mine were the usual, crispy and flaking so nothing to lose. I had some chrome wrap left over so....here is what I started with after cleaning the blank to get a smooth surface. I left the center with ridges cause I knew I could not get that fine ridge detail
Next, cut out a piece of chrome wrap. It looks like crap because it has a thin protective clear over it that is removed at the end. Also adhesive back which was taken off.
Cut each corner on a diagonal, fold one edge around the corner, cut the other edge straight. When done on all four corners, I used a razor to cut out the center.
Used a hairdryer to work all the corners and edges smooth, tacked down along the back with the adhesive backing, where the turn was too great/ no stick, I used a dab of crazy glue. Peeled off the protective coating:
Then installed. The Switch is original. Not perfect but you cannot tell unless you look close. Best alternative I could come up with.
deQuincey
Quousque tandem...?
excellent, very nicely done
bavbob
Boston, Ma
Tyson, let us know how you fair on this. My wife bought this pen applicator and it is very helpful for those small spots, comes in different tip sizes.
bavbob
Boston, Ma
Never be the first to go on a new drug or the last to come off an old drug, I guess I wanted to hear a personal experience since the video looks soooo good........
PimO
New Member
Netherlands
Nicely done bavbob, how did you manage to take the actual switch part (black part) out of its housing? I am ready to wrap the switches and have difficulties taking them apart..
Patton
Atlanta GA
Tape stuff on a door handle that had some chrome pop-up / bubbles. Sand bubbles, apply tape.
Thanks so much, Scott, for the handle.
