Chrome polish product recommendation
Gary Knox
E9 Member Emeritus
West Chester, Pennsylvania
I don't usually recommend products unless I am nearly overwhelmed by their performance. That IS the case regarding a new cleaner/polish for Chrome, Aluminum and possibly other metals that I began using this winter.
Product name is "Killer Chrome", produced by Surf City Garage. I've used at least a dozen different chrome, stainless, aluminum polishes over the past 65+ years that I've been maintaining cars, but I've never had one that gave the sparkling results with very little 'elbow grease' by the user like this one does. It gives a new luster to anodized Aluminum, it produces a bright polish on raw Aluminum, and it gave a mirror finish on the - at least 30+ year old - chrome plated pre-'73 model bumpers on my '74. It is not cheap, but it requires very little on a piece of microfiber to do a bumper segment. I must warn you that it has very low viscosity, so will 'squirt' out of the small hole in the cap if you aren't careful (and all of you bright e9 owners will understand HOW I know that!).
I bought mine from Amazon, as I've never seen it in any of my local supply stores. Link for those interested is: https://www.amazon.com/Surf-City-Ga...Chrome+polish&qid=1559505475&s=gateway&sr=8-3
No relationship or connection other than a very satisfied user. And, I can't comment on it's durability over time/climatic conditions, as the car has been in the garage all but about 2 hours since I used this product on the Chrome and Aluminum.
Gary
Gary
Gary,
I have to say that QUICK-GLO is also a really really good chrome cleaner and rust remover. I have taken extremely rusty tools, mirrors, and all types of chrome to an almost new finish. It also leaves a waxy feel that super smooth. Try this with a 0000 steel wool on extremely rusted chrome and look out. I have to give credit to @Markos for turning me on this incredible product.
I too am a fan of Quick-Glo; old school stuff made in America. That waxy feel is actually wax, which gets into the pores of the metal, rejects water, and helps prevent rust in the future. I use brass wool rather than steel wool; steel wool can leave small deposits in those same pores, which then attracts rust.
Nonetheless, I may give Gary's recommendation a try. If it works well on aluminum, I would be a happy camper.
I have tried several different products to remove the specks visible as light dots and scratches in the photo (actually black specks) which have not worked. Do you think either of these products would work? Thanks...BOB
I was just looking to polish my kidney grills, so this thread is very timely. Being uk based I doubt I can source either of these products. I was going to try brasso!!
Is the kidney grill polished aluminium, or is it chromed?
Drew
Drew,
They are originally anodized. Although some have had them polished and clear/ ceramic coated and or chromed. If the grill is pitted which is very likely, polish won’t produce the right results
Drew
Quick glo is available on Amazon on the UK!
Hi Simon, that's globalisation for you!!
Cheers Keshav, I've attached some photos to show the general pitting on the silver and black areas, and a couple of dings I'd like to improve on. Obviously they're never going to be concours, but any tips to improve the blingyness is appreciated. They don't look to have been previously polished/ clear coated. I would estimate the finish is original
d
Drew, I think the only way to improve that grille is to remove the anodizing by sanding or chemically.
Then sand out the smaller pits and try to repair the small dings. Then polish and wax/ceramic coating/chroming.
The slats are removable, which makes it easier to work on the surrounding grill. But by the time you're finished with the grill, you'll want to refinish the slats as well (black anodized) :D
Cheers Gransin, I'll look into this next week, hopefully I can find a local anodiser shop who camps take this on
Game on!
Drew,
I am nearly finished de-anodizing and polishing my windshield trim. It looked terrible, now it is nearly as shiny as the chrome rain gutter beside it, and the front quarter window trim. IF interested, I'll forward you a write-up on what I did, along with pictures of the process. Send me your direct email via a 'Conversation' please and I'll respond within a few days when I have the write-up finished. Progressively, I used oven cleaner, 600, 800, 1500, 2000 grit wet sandpaper then Killer Chrome Polish.
Gary--
PS: I"m attaching one picture of the Al trim. Compare the trim to the chrome drip rail. .
we, close to the french border, know of herdblank+glanzol a miraculous combination of two products, a deoxidizer and a polishing paste
they work reasonably well and all french specialists are mega happy with it
...in my opinion they should apply the motto “miracles at Lourdes” when pitting or rust is there, you will make only cosmetic improvement
Any recent thoughts on ways to prevent chrome from rusting? I added front fog lights to my car and unfortunately the bolt at the bottom that screws into the bumper has rust that develops and then it leaves a rust stain on the chrome bumper. I'm in a wetter environment (Seattle) and although I'm not driving every day in the rain, the car will see water at some points. The Quick-Glo mentioned above is NLA (sounds as if the owner was involved in an unfortunate death a few years back) so looking for alternatives that aren't only a polisher, which I already have, but perhaps also provides some wax coating to reduce the chance of rust developing in the future.
one thing is to separate the dissimilar metals (fog light / bolt / bumper) with a rubber or plastic washer. the downside of rubber is that it holds moisture. but the 2 different metal finishes are always problematic. the 2nd thing is to replace the bolt / nut with stainless steel.
Ah, both good ideas, and as usual one simple project of adding lights becomes a second sub-project of rebuilding the thing I’m adding
...... but the 2 different metal finishes are always problematic. the 2nd thing is to replace the bolt / nut with stainless steel.
Actually....
In easy words (TLDR) ; choosing stainless material for your bolts will indeed keep your bolts intact, but the carbon steel bumper, or worse, your body, will rust faster.
(Material scientist by education)
The stainless bolt will stay intact far longer then any other bolt on your car, and while that seems like a win, it is in fact, not.
It has one tremendous negative effect. Literally.
Every material has a certain value thatl is called the " electronegativity". In a 2 metal system, the further these values lie from each other, the faster the weak one will rust, and the nobler metal will remain untouched untill the weaker one is depleted.
As the stainless material of the bolt is a different material compared to the chrome and carbon steel, the bolt in itself will create the difference in electrical potential between the two dissimilar materials. When they come into electrical contact (physical or by rain) the sytem will make the bolt behave as an "anode", and your car will be the "cathode".
As long as the two materials keep being in electrical contact, it will result in an ongoing, continous oxidation-reduction reaction. Even when it's dry outside.
E9 members call it rusting.
As a result, the bumper will sacrifice itself to keep the stainless bolt intact.
That is why bolts are zinc treated. As zinc is less noble metal, it'll sacrifice itself over time. Easier to replace a rusty bolt vs a rusty sill. Amhik.
If you'd want the benefit of stainless bolts, but not the downsides it would require two isolating rings AND a sleeve to seperate the bolt electrically which can't sustain serious long term torque. That's why you don't see stainless bolts on cars.
(sometimes called a 'battery effect", google "Jones' Law " ),
My car has no stainless bolts.
Just fresh zinced ones. They rust, and by doing so offer galvanic corrision protection to the rest of the car.
Just replace them in 20 or 30 years before they go really bad.
