jhjacobs
Maybe the new clutch kit need to be driven some miles before working properly..?
No. It still sounds like the clutch is not getting fully disengaged. The only differences with the engine running and stopped are that the throughout bearing is spinning when the clutch is pushed and the transmission input shaft is also spinning. Even a brand new clutch should completely disengage on the first release. I am beginning to wonder if your clutch arm pivot ball pin is worn down. I've never had to deal with such a thing and don't know if it can be shimmed our not.
In my years of changing clutches I have, on several occasions, run into after-market pressure plates that just don't work. Basically they just don't get the contact arms set to the right depth for the throwout bearing to push them in enough to release. I've also run into cracked pressure plate contact arms (even brand new) but this generally results in noisy operation. Are you using a BMW clutch and pressure plate? The right part numbers? I guess a throw-out bearing being too short could be in this category as well.
Also, please make sure your slave cylinder is fully in place and the snap ring in locked correctly. I know this can be tricky to get right since this part picks of lots of road grime. If the slave was not seated by as little as the thickness of the snap ring you could experience what you describe.
One simple test for you: grab the clutch release arm with your hand and try to move it in the direction of normal travel. It should not be loose or rattle (very much anyway).
There is an adjustment point on the clutch system on the linkage between the peddle and the master cylinder. You should have less than about 0.5cm peddle travel before master starts to engage. Even though you have done this, I would go ahead and re-bled the system. The engine does not need to be running for this.
The last thing I will mention is the master cylinder may be going bad. When hydraulic master fail they usually have a slow leak-back like a bad brake master. This the clutch hydraulic use a single stage cylinder it does not seem very likely this is your problem.
