Colours
Sorry, Not true, with a documentation for use to restore oldtimer, you van still get the nitro based color.
Mine is painted with that (glasurit 55 serie)
Breiti
Thank you for this info, but it IS TRUE
you educated me in the exceptions, which I didn’t know
Now I found it for ireland….
In some states you have trouble using solvent based paints, others no issue. Georgia allows anything but my Ceylon paint is water based
My impression initally of water based paints upon their introduction was that they were not as robust as solvent based formulas.
Has that situation improved enough that we can feel confident using the water based formulas on our cars?
I'm wondering if that would make it less problematic to spray my own car in a residential neighborhood and still have acceptable quality.
In my opinion no. They are extremely fussy. Thin and coverage is horrible.
It’s why I stick to the old stuff. Maybe I’m a dog that can’t learn new tricks.
well, the color was the important thing. i should note that the clear coat is solvent based. there are 8 coats of color and 3 coats of clear.
No expert,
But I have heard that they are widely used and results are good, some say better than solvent
Probably it is not the same technique to spray one or the other and you can not expect to behave the same way
Mine was done water based, paint looks quite nice, and it is a complex colour
I will have an expert witness this in a couple of months and he may report back, I am no expert,
this bad?
Hmmmm,
Pros tells me that the metallic particles stand up better in the clear.
I would say, I don't see a different now, but those are only pics.
Breiti
It would be nice if painting a car was as easy as painting a bench so I could do it myself. This bench is the color I would paint my E9.
my understanding is that some colors are much easier in water based. to me what makes all the difference is the prep work followed by good painting. water based can be more blotchy if the painter isn't good / careful. the final step - cutting and buffing is what really gives you the best finished look.
Yes, and to add on to what Scott said….
Even with traditional paint some colors are very difficult. Take Scott’s paint job in Ceylon… tricky color. You better be good and most importantly consistent in your methods and application. Best to paint everything all at once if you are an amateur or even somewhat experienced. If not shades will be different with possible differences in metallics size and dispersion. Air pressure differences… slight variation in thinning will cause match problems with panels panted separately.
Personally I would never attempt that color. I’m not good enough. Chamonix I can handle.
Most bright metallic paints are difficult to paint.
You get "shadows" if you don't lay the last basic layer "fog" continuously.
Mostly that will happen, when the car is painted with dismounted hook on parts.
And those are painted in an different angle.
Breiti
