Dash assembly
tberd62
New Member
Its been way too long since DASCOUP has been on the road, but its in my shop for completion. I am looking for photos to help assemble my dash and console. My files of images are long gone and I would really appreciate any detailed photos or a point in the right direction for threads in the group on this process.
Thanks in advance.
Joe
I would take a hard look at the guide @Ohmess posted above, and do it in reverse order.
Assuming your gauges are out of the pod, install and secure them in place. As I recall taking mine apart, the gauge pod fits into the dash cowl first, and then that gets attached to the dash pad. There are some hidden screws on the back of the dash pad to hold it in place.
Apply some felt tape to the metal dash tray (to keep things from rattling). Attach the curved dash parts to the lower wood tray (I am assuming your lower wood dash tray is assembled with vinyl covering and the little wood dividers. If not you will need to cover it and then add the dividers).
The curved wood dash parts are attached to the lower dash tray using small wood screws. I suspect you will want to test fit the instrument pod at this point to be sure all of the stuff is properly positioned.
The dash tray has small captive nuts on the bottom, so bolt it down using the proper size bolts or machine screws. Tighten it snugly, but don't apply too much torque to the bolts or they will pull the captive nuts loose. IIRC there are some clips holding the top of the dash in place, but that may be more for the dash pad.
Install the dash pad and instrument pod on top of the wood. It gets held in place with clips along the top edge of the dash, and some very hard to access screws. Usually it is easier to install this withthe front glass out, especially when it comes to connecting the defroster vents to the dash pad.
Somewhere in this process you should connect the gauge harness to the gauges.
Hello,
Our forum member Barry.b made an usefull report of the dash removal
Thanks in advance.
Joe
Need a spare license plate?
