Does anyone know where to source the male 6 & 9 pin plugs that would fit into the diagnostic ports in the engine compartment so that things can be wired to them?
			He does in fact sell several of the diagnostic plug parts.Ask Pat Allan on the 02faq
Pretty easy Steve - both 6 & 9 male plugs donors are in SPEEDO WIRING.Does anyone know where to source the male 6 & 9 pin plugs that would fit into the diagnostic ports in the engine compartment so that things can be wired to them?
OK...I'm curious. what are your ideas (or anybody's for that matter) of things to wire to these ports?
Tune up tach, dwell, RPM, volts, amps,.....?
That is clever Steve. Once you get that tach/pin setup all figured out, please share. That would be a real time saverI am going to use the 6 pin one to attach to my tachometer without having to hook it to the battery and #1 spark plug wire. Like a quick connect setup. The original 6 pin diagnostic wiring (usually removed at some point) included the induction wire on #1 cylinder for the timing light which I will use instead of hooking the one from the light which is a pita with the CSi airbox in the way and gets hot as hell too. For the 9 pin I am not sure yet but if I have too much time on my hands I'll figure something out![]()
					www.bmw2002faq.com
				I guess you know about this? I see you on 2002 FAQ.
Diagnostic Tool for BMW model 2002 User Manual
Congratulations! You have purchased a unique electronic tool specifically designed for tuning of the BMW Model 2002 - by a 2002 enthusiast! This unit is100% hand built. To use the tool - First make sure the car is in the NEUTRAL position (and/or Park for automatic cars). No key in the ignition, a...www.bmw2002faq.com
That is clever Steve. Once you get that tach/pin setup all figured out, please share. That would be a real time saver![]()
I have a push button I made years ago for the E28 and it works on the E9. It's great for cranking the motor if and when you might need that. I have used it for valve adjustments but it's to easy to go past so I just take the fan off and put a socket on the crank nut.Yes, but I don't have use for the dwell function (123 distributor), AFR (have one), or remote start and I can use my timing light for the RPM. Maybe for the rare occasion of starting the car form the engine compartment I'll rig up a push button.
I see you can set it to 6cyl for the tach function, but will all other functions work with an M30? Where can these be purchased (or questions asked)?I guess you know about this? I see you on 2002 FAQ.
