I tried that. It helped. I found when I tightened the cap it squeezed more air out. So I loosened the cap to draw oil past piston and then tightened to force more bubbles out and so forth.I found a trick to getting the bleeding going is to loosen the 19mm cap on its threads a little, start pumping with the long screwdriver, when oil starts to pass the threads then tighten the cap and keep going until it’s firmed up. If you shake a clean new piston you should be able to hear the bb rattle inside.
