Extra wires and switch ignition
larry00700
North Carolina
Hey guys. Pulling this thing apart and want to fix the wiring under the dash, at least getting a turn key ignition back in place. There are also a few extra bits and bobs put in place that I don't recognize. Has anyone seen anything like these buttons before, or have an idea what they were put in place for?
I don't want to put juice to it before I figure out what's what.
Any help would be great. Of course I can always add more pictures if something else needs to be seen.
Thanks guys,
Larry
Sent from my SM-G950U using Tapatalk
Markos
Seattle, WA
Ugg what a mess!
You know, I just went through this. I pulled my radio and the rats nest of wires. I had two flip switches and a battery gauge as well. It all cleaned up beautifully but I accidentally yanked a power wire to #5 on the fuse box. The car was dead for a week before I spent time tracing the issue. Pay attention to the terminal ends. Look for clear factory connectors. Electrical tape is a sign of tampering. Plastic tubing is factory. Those blue and yellow autozone-looking terminal ends are not factory. I also spy a green wire with an inline fuse. You shouldn't have random red wires dangling about.
The orange button is your rear defroster
The red buttons are the factory breakers for your windows.
The black plastic switch is some type of owner-installed switch. Trace the wires back
The big flip switch looks like it is related to the ignition switch, which has a red, violet, and green wire. Edit: I see from your post that this is probably an ignition switch bypass. I'm trying to figure out how that works. I would think you would need a momentary button for a starter and a switch for accessory power.
autokunst
Milwaukee, WI
That looks a bit like the underside of my dash. There is/was a remote box for an alarm which was wired into way too many bits, an old school radar detector hard wired in, an aftermarket radio, and I don't even know what else yet. I haven't fully tackled it, but am glad to read that others have similar situations. Good luck, and thank you for posting such great pics. I am embarrassed to show this area of my car. :eek:
The small can relay looking device might be the old buzzer for seatbelts/key, it fits between the steering column covers.
bluecoupe30!
Yes, I know what you mean. Last time I was in there, with truly the best of intentions, I mean I was cleaning up terminals and improving ground wire contacts and such...then sunroof stopped working :(.
It is minefield of risk. Don't go in there alone!
