"I actually think with the 4-speed the 3.07 would make sense to lower the revs in top gear. That said I wonder what happens in first."
Diff ratios are simple, if you go 10% taller, you lose 10% torque (relative, in any gear). Going from a 3.64 to a 3.07 will cost you nearly 20% in any gear. That's a lot as E9's aren't very fast cars in any gear in their original configuration.
My suggestion is to go with the tried and true combinations: These have proven out over time with thousands of enthusiasts and by the factory.
4spd with 3.91 - good for the track where it's rare you will spend much time at 120mph unless it's a real race car.
4spd (direct 4th) with 3.07 - good for highway cruising, but you'll definitely feel the loss of torque in 1st gear on a stock or near-stock motor. This was the standard setup for the early E-types sold in Europe. It's a great GT setup if you want to keep the 4spd. But, if you do things like mountain tours with steep hairpin turns, I'll bet you will end up 1 gear lower than you are accustom to. You might even find yourself using 1st gear in corners (if you've done the Mount Equinox hill climb you know what I mean). Good excuse to learn double clutch downshifts. If you've got a nice stage II 3.5liter B34 or B35 setup for low end torque, well that's a different situation.
5spd (OD 5th) with either the 3.64 or 3.45 (the latter having long legs if you do a lot of highway cruising in your classic car). Personally, the idea of cruising down the highway for a couple hours is not my idea of fun, but I am sympathetic for those of you who do things like drive from Laguna Beach to Monterey or Phoenix.
5spd (CR, direct 4th) with the 3.07: To me this is the sweet spot for people with big displacement motors. This was the setup BMW picked for the Euro 635Csi (which had slightly larger diameter tires). With a powerful enough motor, this might even be fun for HPDE events. Doesn't Duane Sword run this setup in his Alpina?
