fs manual sunroof cables SOLD
aearch
pleasant hill , ca
NO THERE ARE THE SAME
EVEN SO THE CABLE WOULD JUST RUN INTO THE
SUNROOF TRACK A BIT FURTHER TOWARD THE BACK
THE CABLE IS THE SAME THE DIFF
IS THE PART THAT SLIDES IN THE TRACK IS
METAL NOT PLASTIC SO IT WOULD NEVER BREAK
http://www.rogerstii.com/bmw-e9-3-0cs-sunroof-cable/
zak2002
Costa Mesa CA
the cable lengths matter very little. Its the height. If you have your old plastic ones check the height against your metal ones and adjust accordingly. After that you may want to grind the column support down to bare minimum. This is what works on a 2002
[email protected]
