I also modified my blasting cabinet; it is same construction, as it all comes from China.
This valve at the bottom is next up on my list; it seems to solve the same problems (blocked lines) that I suffer as well + I like the idea that it facilitates quicker change of abrasives. Switching korund to glass and back now means o have to lift it up and shake it out into a bucket; not convenient.
Like Marc, the OP, I also use glass beads to peen aluminium at a lower pressure. I agree it works well.
Regarding lighting I use a high output LED that I just lay flat on the glass plate. Best solution regarding lighting if you ask me, as you simply don't have to worry about your lamp getting blasted, and you can also use the lamp for different purposes, like under your car.
I also hooked up a dust extractor; I use a normal vacuum cleaner running but between the blasting cabinet and the vacuum cleaner I put a cyclone separator that I purchased at a local second hand store. It's actually a thing that is used to clean the ashes from your fireplace, so all steel and no plastic.
Works great to keep the main stuff out of your vacuum cleaner.
regards, Erik.
