66toaster
After 46 years they no longer hold the hood up. Looking for the fix. Is there a spring in that long hollow bar that goes across the front of the engine bay? Need advice. Thanks.
you can make a new one from 1/4" diameter bar stock
lust bend the ends and then reattach the end holders that the bend sits into
the torsion on the bar is the spring
you would have to bend one end slide it thru then bend the other in the same direction
Thanks for the lead. My car is parked off site, so I can't look at it immediately to see how the tube is connected at each end to the hinges. Is it possible to just replace the torsion springs that are inside that tube, or does that involve cutting to remove the tube & then welding it back together? None of which I can do myself. Thanks.It's not your hinges that are worn out - it's that tube that runs across the width of the hood, plus the two arms that attach to the body. As HB Chris wrote, there are two torsion bars - springs if you will - inside the tube that attach to the R and L arms. Replacement tube-arm assemblies should be available and installing this part is a DIY job of medium difficulty (wear eye protection!). Maximillian Importing shows it as p/n 41611814312, priced at $203.59. See: http://www.bmwmobiletradition-onlin...el=3425&mospid=47810&btnr=41_1219&hg=41&fg=35
I will be selling my complete assembly. Painted silver and in exceptional condition.
I believe the assembly is original 1970. Still works perfectly. Thinking 150 for it, but shipping would be expensive. Where would it be shipped to?
Just heard from Max; the part number you cited is no longer available.
I think my solution might be to install an old fashion prop rod. I did see a solution for a 2002. The owner installed 2 stabilus gas struts on each side.
www.e9coupe.com
