Before removing the E9 wiper motor. Tape the windshield wipers & arms to the windshield, this will ensure the linkage is in the correct place when reinstalling the E24 wiper motor.
Remove the wiper motor by removing the linkage nut first, may need to pry the arm off of the splined shaft with a flat screwdriver. Then remove the 3 10mm bolts. With a little wiggling the motor should be fairly easy to remove & unplug.
The E9 wiper motor has a separate ground wire spade on the body of the motor.
The E24 will fit perfectly. Just need to modify the ground wire with a crimp loop to bolt to the motor as shown.
Reassembly is straight forward after the small modification. I did this at The Vintage in Asheville with Rob Siegel & Billy Revis in under 30 minutes.
