scanty
So, I've had the opportunity to putz around with the wires while the ignition switch is out. Before now I had believed that the Green wire was the Starter Wire, while Red was Power, Black ground, and Violet Accessory. However, by mere accident I discovered that Black appears to be the starter, as the engine cranks over when engaged, and the green one merely gives my engine warning lights on the dash, and violet is accessory. Thus, if the green wire is activating things on the dash, what is this wire? The interesting thing is that it appears that it (the green wires) coincides with the last (Cranking) position on the switch. Does that make sense? Shouldn't black be in the furthest key turn position?
