Oh Hose- you have been down in the Quarter again….
@Stevehose and @Luis A. : In the thread below, you seem to indicate that you went along with what @Sven and @deQuincey were suggesting: Putting the wider end of the bushing at the top. Therefore installing the bushing from the top (inside the trunk) instead of from the bottom. Just like in the schematic above, part 11. Did you change your mind and do it the other way for some reason?
Which way does the rear shock bushing go?
Wider end topside or other way around? Seems like the wider side should go below to keep it from popping through the tower hole from forces below but parts diagram shows wider side is on top side. What say the experts?e9coupe.com
I have to say that when using that big Carl Nelson washer, it would make it a lot easier to slide it on the collar of the bushing first and then push the narrow end of the bushing with the washer already installed from the bottom. Instead of pushing the narrow end down from the top and then having to try and slip the big washer onto it from the bottom inside the shock tower.
It is recommended by Carl Nelson to avoid the issue of cracked rear shock towers.do not put the big thick washer, it is not an stable system
unless you weld it to the turret
I’m not sure that’s going to help, I had them when my tower let loose.It is recommended by Carl Nelson to avoid the issue of cracked rear shock towers.
As Chris said, Carl has been doing it for 40 years on countless coupes. So, while it may not be a perfect solution, there seems to be plenty of empirical evidence to show that it is an improvement over not using anything
I would tend to agree with DeQ here: the washer will concentrate the load mostly on its edges. When only the rubber is used, there is not such a load concentration; the rubber tends to deform mostly on the edge and therewith spread the load.
Secondly, I think that (correct me if I'm wrong) most blown shock tower have a tear that originates from one of the spotwelds. Taking a rough, eye ball approach: doesn't the edge of the washer line up with roughly the circle that the spot welds make? If they match, then the (-if first argument above is true-) it would concentrate the load exactly at the weakest spot(s). Not sure if that is wise.
If I were to use a washer, I'd try to make it to it's max dimension possible about 8-9cm/ 2,5 to 3 inch), and round the edges. I'm guessing that the above depicted washer only has a dimension half of the width of the tower's flat spot, wider would be better: every 1 mm add 3.14 mm of more material to spread the forces.
I'm struggling what happens as the shock mount chances angle during driving. No clear thoughts in my mind on that...
You make all kinds of good points as usual Erik. But using your own “wider would be better” isn’t a wider washer better than the much narrower rubber bushing? Any way you look at it, a washer will spread the load over a much larger area. Therefore, in my mind at least, it will reduce metal fatigue on any specific weak point, wouldn’t it?I would tend to agree with DeQ here: the washer will concentrate the load mostly on its edges. When only the rubber is used, there is not such a load concentration; the rubber tends to deform mostly on the edge and therewith spread the load.
I'm struggling what happens as the shock mount changes angle during driving. No clear thoughts in my mind on that...
I don’t have a horse (or even a cat ) in this race. But as a general rule, I tend to trust the opinion of people who have many years and many cars worth of experience.
In this particular case it seems that the worst that can happen by using is this large washer is that it would not improve things. That seems like a risk proposition to me.
But I’m always interested in hearing different opinions. What would be the rationale against using it?
i know that we all love CN, but that might not be a sufficient reason, love is sometimes causing more problems than benefits (i did not knew it was a CN invention, not judging the inventor here)
try to look at it as a mechanical system, if the tower and the washer are not welded together it might be difficult for them to work together, i assume that the idea is to spread the force in a bigger surface which is a good idea
the force exerted by the shock is not perfectly perpendicular in all of its travel
the relative displacement forces might not be good for the system
i would not use it
