LED 3rd Brake Light Instructions & Installation Photos
Here's how to make one, these directions are for BMW E9s and 2002s, so your measurements for extension wires may differ.
Here's how to make one and install it.
The 3rd brake light is an LED strip 1 foot long Alpena 180°red with 60" of additional red & black wire soldered with heat shrink insulation at the joints. Then red & black alligator clips soldered to the wire ends. Then put little pieces of electrical tape around the wires to hold them together. It attaches to the upper center of the rear window seal with the wires run under the lip of the window seal to a hole under the parcel shelf. Then under the white fender welting, under the gas tank trunk board to the brake light tab and ground on the passenger side tail light.
Need a soldering iron, flux, solder, Alpena LED, extension wires, heat shrink tubing, electrical tape and alligator clips or tap into brake light circuit and ground.
Alpena lights are available at Advance Auto Parts or on ebay. They come in 180° and side light red. 180s are for low angle roof lines, side lights for steep angles.They have white logos and cut lines which I color out with Industrial Grade Sharpie.
I used to buy the extension wire, heat shrink tubing and alligator clips at Radio Shack.
Walmart now sells Alpena lights with a pin-&-clip system. There are 4 pins 12v, R, G, B, I keep the 12v & Red & clip off the G & B pins. Then the directions are the same with shrink heat tubing & soldering outlined above.
If you have any questions I'm happy to answer.
Having just finished this project this week, thought I’d add my two cents. I used a strip similar to the one in the original post, but found that it wasn’t adhering well to the glass. I instead turned it 90 degrees and shoved it into the small space between the edge of the headliner and the roof. It wedges in perfectly and still provides quite a bit of light. I actually sort of like that rather than being discrete LED point lights it has a more diffuse “red bar” look because it’s the light going through the side plastic of the light strip. This is an easy 30 minute mod that seems to add safety and isn’t even visible when it’s not in use. I tried to take a photo of it from the outside but had too much reflection. Trust me that it isn’t visible when looking from outside the car in
What light is that?
Where are they available?
Amazon. $12.99
I soldered mine onto the ground area at the rear brake light and then used a tap on the wire going to power the bulb. The wires on the LED won’t reach all the way to the back of the car so you’ll have to extend them but that’s a pretty easy job. After it runs down the side gasket of the inside of the rear glass you can have it drop behind the rear seat area and then go through that little pass through to the trunk, then drop into alongside the floor panel to join the rest of the cabling coming up to the brake lights.
I've been planning on adding a third brake light but with the addition of yellow ends to act as turn signals as well. It means more wires to hide and some additional width, but it should be about the same effort to install. I've yet to find the perfect product though, the search continues.
Interesting. Maybe something like this?
https://shorten.ly/O8R4i
At .8"x8" it is not that discreet. Available in 48" as well, but not seeing in-between sizes.
the downside about that piece is its pretty wide and will visually show up, even when not being used. looks like 8" x 1" x 3/4" +/-. the good advantage is that it has turn signal and reverse light. i have seen some that are narrower with multi color LEDs all in one line that you could do brake, turn and reverse.
here is one available as a single mode or multi mode. its 35" long, 1/2" wide and 3/8" thick. i already have 4 bulbs in the taillights for running lights with 2 of them for brake lights. i tend to think i just want a big 3rd brake light ... i already have the 18" strip from @adawil2002 and its barely noticeable when not being used ... and i like that.
or one like this - which has red + amber but also does running lights, brake lights + turn. doesn't really give the other dimensions
