starcruiser
- Messages
- 257
- Reaction score
- 86
Cornishman,
The blocklayer site is great! You can measure the diameter of your pulley and then adjust the template to that size and print it out. Line up the TDC marks, tape it to the pulley, then mark the appropriate notches you need, 3 degrees BTDC and 25 degrees BTDC. I see also that can print out a tape to go around the circumference of the pulley and do the same procedure.
Thanks, Starcruiser
Thanks, Starcruiser
