Hi all. I'm working on getting the M10 in my 2000CS running smoothly, but I've never really played with side-draft carbs before so I'm having a tough time. I'm running the stock Solex 40PHH carbs that came on the car. No matter what I do I can't seem to get all the cylinders running at the same time. So far, here's what I've checked and done:
1) Compression check with 180 psi across all cylinders
2) Changed out points for a Pertronix electronic module, upgraded to a flamethrower coil, and timed using the procedure from this thread (https://e9coupe.com/forum/threads/m-10-timing.29750/)
3) Adjusted valves using procedure from owners manual
4) Carbs were rebuilt a couple years back from this company (https://www.partsklassik.com/c-22-carburetor.aspx). After the rebuild they never had fuel in them and sat inside for a couple years, but they don't seem to be leaking and I checked that the jets and needle valves were clean before starting.
5) Checked for vacuum leaks while the engine was running with a propane torch
Despite all this, I have a consistently low vacuum through the throat of the carburetor on cylinder 4, and it isnt't running currently. I fooled with the settings for the idle air mixture and I have had it running, but then cylinder 3 was dead. The low vacuum concerns me because I don't think it's dependent on the mixture, or whether the cylinder is running, but I don't know whats causing it because I have good compression and everything else seems right.
If anyone has any other thoughts or advice it'd be much appreciated. Thanks in advance.
