MAHLE 10:1 High Compression Pistons 3.5 engines
what size pistons for the M90 engine and do you have ring sets for them too?
Is there a price?
Thanks!
ps- do you have 10:1 pistons and ring sets for 92 and 93.4 bores?
I produce them in bore sizes 92.5mm, 93mm, 93.5mm, 94mm, 94.5mm and 95mm. Compression ratios 10.00 ,10.5 and 11.00 to 1 for on road use and inboard pin boss race pistons up to 14.00 to 1.
Complete piston sets with rings, 4130 pins and locks are $995.00 as pictured.
Pistons pictured are 2618-T61 forgings and come standard with full 3D internal milling, 3D dome (configured for chamber type used), accumulator grooves, double pin oilers, diamond honed pin bores, offset pin bosses, 3D valve pocket milling.
I am beginning to offer shelf part numbers for certain applications which will bring the price down a little while retaining the same quality.
If you would like to contact me I would be happy to go over in more detail.
Paul
913-728-2211
