FastCougar
OK guys, I have a lot of video and pictures which are now being uploaded, but the videos need to be pieced together and will be uploaded later tonight. In a nutshell this is SOLID with virtually no rust. There are imperfections since it wasn't a complete garage/trailer queen, but the lack of rust is a testament to it's pampering and never sat outside or driven in the rain unless caught off guard as the pictures and video will demonstrate. There are 87 new photos uploading, so I'll simply link to the photo set on Flickr as there are simply too many to show in this thread, but I will post a few of the highlights in a few minutes.
A lot of the value depends on the market itself and I've got my eye on a few eBay auctions that have run recently and a few that are currently running and featured on BaT. Based on what others are going for in inferior shape and various stages of "non-stock" condition, I'd base the value around $35K. Honestly, the car is in such great shape that it's easier for me to point out the imperfections with full disclosure than to be a used car salesman and trump up the car. Your thoughts and input are greatly appreciated!
Getting ready to do my thing ...
Driver's side front fender areas of concern ...
Driver's side from shock tower ... road grime only here ...
Behind the Driver's side fender ... looked through the triangle onto the firewall and it's all clean (show this in the video, hard to get on camera, hopefully it shows well on the video).
Slight surface rust on the leading edge of the rocker lapping edge, metal is solid, only surface rust as the coating has started to peal off.
Passenger's side looks very similar (I show in detail in the video)
Only real rust I saw that might need attention is in the spare tire well.
Outside peal through, doesn't go through to the inside. This is where the finish blistered from exhaust heat and exposed bare metal to the elements.
Looks as though this was previously fixed, but without removing paint, not sure exactly what was done.
I rapped on this area from under the car and within with a 3/8" ratchet and they are solid, so this appears to be surface rust.
Overview shot
Rear shock towers are near perfect with only slight surface rust
Passenger's side rear tower was squeaking, so I retorqued the nuts ... note the difference in the top rubbers ... squeaking is gone, but I'd replace the top stop bushing on both to match. The struts look newish, I'd have to hunt the paper trail to see when they were replaced. Whoever did it reused a stock rubber (I suspect this one since the other looks new and nowhere near the same).
Driver's side front frame rails ... road grime only
Driver's side floor panel and rocker seams, light hints of surface rust through pealed undercoating.
I won't bore you with passenger's side shots as it's a mirror image.
Close up showing it's surface peal ... like I said, it's been driven, but well cared for.
Wheels could use a bead blasting and refinishing, but no major gouges or curb rash to speak of. Roundel need refinish or replace and 1 is missing.
Most rust I found was on the factory exhaust
A few paint blemishes (rock chips covered with off-color match)
Passenger's side door leading edge ... slight surface rust after paint chipped.
Blemished passenger's side roundel - needs replacing (will have to ask Dad how this happened)
Hard to see, but mid-frame there is an ever so slight crease in the body where something hit it.
Parking damage to the passenger's side rear CSL fender flaring.
Chipped fingernails
Paint scuff (down to primer, not to metal), but this picture also shows how perfect the hood is fitted.
Hard to see, but similar scuff around the headlight bezel ... tiny ... rock chip perhaps? Again, only to primer, not to metal.
Interior trim issues:
She's see her fair share of sunny days as evidenced by the worn driver's ingress/egress bolster wear.
Starts right up every time ... again and again ... leading to hand/key wear
Driver's side visor pivot joint needs replacing.
Slight "cloudiness" to the fuel/temp cluster cover.
Headliner slash (no idea how this happened, probably Dad being careless moving something).
That's about it for blemishes folks ... I cover a few minor points in the video, but overall, she's SOLID with minor imperfections here and there. Your thoughts?
Overview shot
Chipped fingernails
