- Messages
- 422
- Reaction score
- 264
Hey all, I picked up my E9 this morning after the new radiator install and thanks to SFdon for getting me the right replacement. It took a few more weeks as the local repair shop unfortunately damaged the lower passenger side rear quarter panel and part of the door when they drove it out of the garage into the lot to take in some new cars (Covid parts logistics has screwed up their repair times and lot car placement) while my repair was paused awaiting the radiator. The scratch was huge and when the photo was sent to me, I was horrified. But what can we do? After seeing the repair today, it looks really good, especially the paint match, but some visible orange peel so that needs to be wet sanded out, I think, versus the super smooth Coupe King paintjob I had done in 2011.
Anyway, so Don's aluminum radiator is now installed, along with new upper and lower hoses, a temp sending unit and 80 degree centigrade thermostat. My car, before all of this, always seemed to run cool - the coolant temp needle was typically in the 4 to 4:30 pm range even on the hottest days, worst case 3:30 or even 3 pm. But on my drive home today, I noticed the needle was more in the 2:30 to 2:45 pm range (see photo) -- above the halfway point on the guage and, uncomfortably for me, closing in on the red zone. So I got home and hooked up my Megasquirt computer to see what temps I was getting and they are here after a few hours of cooling down:
4 pm position - 170 degrees
3:30 - 182
3:00 - 190
2:45 - 194
2:30 - 197
The needle does not seem to point above 2:30 (at least on the cool 42 degree F day we are having here in Virginia today) and stayed around 197 degrees, more or less. Sadly, I never documented my engine temp relative to the temp guage before today to compare those actual temps with what I've grown used to seeing on the dail since 2007, which all seemed normal or maybe even better than normal...
Other notes: fan is operational. Coolant was flushed, too, in the repair.
I thought our cars ran about 180 degrees overall, but now I'm curious if I simply need to get use to the new gauge baseline reading, or if this new radiator runs hotter, or if the new temp sending unit or thermostat are to blame?
Thanks for any feedback, especially from Don Lawrence.
Wayne
3:30 - 182
3:00 - 190
2:45 - 194
2:30 - 197
Wayne
