oil filler cap seal
30csl
London/Herts
Anyone got a source for new oil filler cap gasket/o ring as I want to get mine chromed.
krauser
bay park, ca 92117
Oil filler cap gasket
Mercedes part # 102 018 03 80 or 111 018 00 80(same part), perfect fit, should be readily available for $3,
thanks, krauser
deQuincey
Quousque tandem...?
Brilliant help guys, many thanks!
but there is a possibility that the problem is not the rubber gasket
let me explain myself, my first oil cap had the gasket replaced and still spills oil
ib that case the problem was an interior break of the cap construction itself, if you look carefully you will see how it is built and you will quickly identify the leakage possible ways
lets hope that in your case a new gasket solves it all
regards
30csl
London/Herts
Hi DeQ, its not that its leaking, just that I want to get it chromed and the old gasket seems too brittle to survive removal and refit - i may try heating it and then removing it.
