jhjacobs
This is probably a bad topic, akin to asking about coupe values, but does anyone have any "scientific" opinions about what is the best oil to use in a standard coupe engine? I really don't know the heritage of my engine but I know it has been worked on before I got it. My odometer is at 5,000 miles (105K, 205K, 305K, ???). My compression is good and even and there is no indication of undue engine wear (quite and smooth operation). My head has a '77 cast mark. I have no oil spots under the car and oil consumption is modest (1/2qt every 2-3K miles). I have typically used 20W-50 Castrol GTX and avoided synthethics. When I put synthetic in my E3 years ago it started leaking out the main seal and many of the gaskets - maybe conincidence but I've seen this before on other older engines too. So what's is the best oil or is there any difference today?
On the topic of oil filters, my oil filter housing seems to be from a later model 2.8-3.5 engine. I had one hell of a time figuring out what filter to purchase because the BMW part# cast into the housing is 1266373 along with Purolator PM 2433. According to my ETK database this is not a valid number. I did find that the 11422 1266372 was used on '85ish 2.8L thru 3.5L and the filter seems to fit properly. So, does anyone have a fact based opinion on the best filter to use? I have found the following filters on the market for my housing:
Purolator L30084
Fram 2965 (this actually does not appear to be right)
Wix 51732 (Jiffy lube seems to also list this number)
Napa NASCAR NFI 91732
Napa Gold FIL 1732
NAPA ATM OX41D
Mahle ATM 72128
Bosch ATM HU9303X
If this starts a rant thread, my apologies in advance.
Purolator L30084
Napa Gold FIL 1732
NAPA ATM OX41D
Mahle ATM 72128
Bosch ATM HU9303X
