Hi all,
I have taken the engine in my E9 CSL apart because the cylinder head developed a crack last year. It took me a very long time to find the right type of cylinder head (with the oblongish water channels) so if you have one or more of these earlier heads (pre 1978 ca) lying around, be sure to keep they: they are very valuable - at least until BMW starts producing these early heads again in the beginning of 2018
Anyway, I am asking your assistance not in connection with the cylinder heads but with a bad situation with my oil pump. Now that the engine in taken apart I see that the oil pump chain is very long (= worn) so that definitely needs changing. I also have noticed that it takes 'some seconds' for the engine oil light to come off so I thought that I would replace the pump --- only believe it or not - the oil pump is NLA !!!!!!
I spoke to Nesch from W&N and he told me that the company who produces the pumps has gone out of business and that pumps from other M30 engines (like E12, E24, E28) DON'T FIT!!
Can this really be true? Are the pumps or the 'suction mechanism' so different between early 70ies M30 engines that I need to find a pump from an E3 or E9 to be certain that it fits? I can hardly believe it.
I am hoping someone on this forum - somewhere in the world
can provide some facts about this issue. I would obviously prefer to find a new pump, failing that I need to find a pump which hasn't covered 100.000s kilometer. But first obviously I need to find out which oil pump will actually fit in my engine. It's a 3003 cc engine from 1973.
Tips, hints, insights are much appreciated.
Torben
Torben
