I have used VHT paint for my exhausts in the past and it holds up nicely..........VHT=very high temp.
Does that product need heat to cure correctly? I mean, must you remove the downpipes, paint them, and reinstall, then start motor to produce heat to complete the process?I have used VHT paint for my exhausts in the past and it holds up nicely..........VHT=very high temp.
Or perhaps you sprayed what you could, while on the car, then ran the engine to heat and cure? CURE-ious![]()
Also famous is how difficult it is to remove the product if it touches your skin.
[USER=29993 said:Rex Kapriellian[/USER]]Is this sold in rattle cans?
My guess would be not. The stuff dries to such a rock-hard consistency, that the rattle can nozzle would clog up after the first use.
It’s also more nuclear when in aerosol form. It can be sprayed from a gun but much precaution needed.
Can you define "nuclear" in this context? More flammable? More likely to overspray, where it will be impossible to remove? More likely to be inhaled?
