Power steering fluid USA
Thomas76
Michigan, USA
I've tried to find 3 or 4 of the 20 approved power steering fluids from the manual, seems they are discontinued.
What are y'all using in the us that may be at a local parts store?
scottevest
Ketchum, Idaho
Related question: my steering is very noisy. Not sure if I need a rebuild or simple filter change. Any ideas on where/how to change the filter?
Keshav
Germany
scottevest
Ketchum, Idaho
There is a plate above the filter -disassembly is required.
So just to be clear, I have to go beyond where I see the liquid? Can I clean the filter or do I need to replace it? Sorry for asking all these stupid questions but I am not that mechanically inclined
sfdon
sfbay area
Drain the fluid, Disassemble, toss the filter, install new filter, reassemble, Fill with fluid, check level after running engine.
Drew Gregg
Ft. Lauderdale
My Reservoir is out of the car being painted. Thanks for the answers to the question of what fluid to buy. I hope the Castrol ATF is available here in the USA. Now to find that filter. Does anyone have a part # ?
Drew Gregg
Ft. Lauderdale
I searched several websites and did not find the Castrol Transmax Dex3 ATF. What have forum members in the USA used? Has anyone used a synthetic ATF such as Redline?
bavbob
Boston, Ma
Search for just Dexron III, penzoil and valvoline Dex III on Amazon. WRT synthetic, I never believed the thought that you will uncover leaks if you switch to synthetics but my Bavaria is an automatic and uses Type F so I use Redline racing ATF. I sprung a leak at the speedo insertion after switching. Not a controlled experiment, conclusion based on chronologic observation.
