Questions About Blinkers
Berkautobarn
New Member
New York NY
Hey Everyone, I am having this occurrence on my 1974 3.0 cs when you switch the blinker on it just stays on and does not pulse. It happens on both sides. I am wondering if the mechanism is grimy and needs to be cleaned or if it’s a further wiring issue.
Any thoughts here? Thank you
Try a new relay - there is the original one and a newer digital version
The device inside what many people incorrectly refer to as a "relay" (my dad called it a flasher can) is actually something quite different in its original form as used in the coupe. It's fiendishly simple but they do go bad sometimes. It's just a piece of filament wire spiraled around a bimetalic contact strip that temporally shorts out the filament when it gets hot, but only for a blink because as soon as the lights come on the filament that was heating up the strip starts cooling down and the bypass contact opens up again, heating up the filament. The blink interval is dependent on all sorts of things, including the bulbs used, harness resistance, terminal and socket corrosion. You can still the old fashioned kind made by CEC for about $10 US and it works fine in our cars. The first few minutes of this video explain it I better than I can.
Do the emergency flashers work?
If you received your new relay, did it fix the problem? Ask me why I care? :cool:
The new relay came in and did not change anything unfortunately. I have not had time to diagnose more but will dive into it this weekend. I think it is certainly worth trying a new one if you are having the same issue.
If you have a test probe which I have found tremendously useful for sorting electrical issues you can follow the connections down and fire 12v at various points and quickly see where the break is. If you added an electronic flasher relay make sure the connections are correct as mine did not work at first but was my fault for reversing a connection (I'm sure you did but always worth double-checking.)
That's what's great about the old-fashioned flasher cans, hookup is foolproof.
