Redesign/conversion of early-style rear armrests to newer-style
e9Leveque
Seattle, WA
Title hopefully self-explanatory. The early style armrests don’t have a way to house the seat belt roller. There’s a whole other thread on seat belt options some of which aren’t available to me, so at the moment I followed the route of Dan Woods (I believe) who had fashioned a metal bar that allowed the seat belt roller to sit in front of the armrest but be anchored to the frame behind the armrest. It works but is a bit clunky. I’m redoing my interior so figured now is the time to change old to new. I couldn’t find any new-style armrests so am going to write up my attempt to convert between old and new.
I’ll start by saying that these armrests are very non-structural. It’s all a bunch of 3mm plywood held together with staples and the only reason it doesn’t fall apart is the foam holding it together. My plan given today’s technology and manufacturing is to try to mock this up in a way that could be made in wood if that’s your deal but could be easily made in ABS plastic for those of us with 3d printers or access to online printing services. Although it’s large it’s really two medium size pieces which can be assembled.
I’ll begin here with some pics showing the old-style armrest that I purchased from @Koopman and its teardown. I made a sketch with measurements on some wrap paper that I recycle from the sterile processing people at work - great stuff, it’s semi waterproof, durable and works well as drop cloth.
If anyone has pictures of the internals of the newer-style armrests, please post them here. @Dlc sent me some but the more I have the easier this job should be.
First pic is my current, rest is the teardown
I am a bit unclear on the differences between old and new rear armrests. What is the partition date?
My car (about 06/72) has arm rets that look pretty much like yours, but I have roof mounted anchors with the little flaps to store the shoulder belt up top. The retractor is down on the floor by the back the front seat.
I can take some pics of my rebuilt armrests if you want.
For the 74 model year they widened the armrest, made a slot for the belt and mounted the retractor behind it. It uses a horizontal latching mechanism. There is also a clip on the wood below the quarter window to guide the belt to your shoulder.
Scott, your option is the one that many have chosen, I don’t have the anchor point in the ceiling and don’t have an easy way to mount the roller on the bottom of the B-pillar. Thus it’s either something like the first picture I posted above or trying to hide the roller as in the 1974 cars.
Here are picture @Christoph. Bonn sent me of the two types of armrests. Look at the final vinyl-covered ones to see the cutout and plastic guide, the issue is that one needs to make room back there for the roller.
@Christoph. Bonn one question is whether the angle between the rectangular base and the upright is different in the two versions? This project seemed like more than just carving out that large block of wood at the top in the original, it seemed to also need a slight angling forwards of that upright at its bottom to gain another few cm of room at the top, since small angle change at base has greater linear change at a distance. If there is indeed an angular change, any chance you or someone else can measure the new angle?
Also, any chance that you have paper tracings of those new parts that you cut out or fashioned from wood?
And @HB Chris you make a good point that if adding/changing to this option one wants to purchase a seat belt which is designed with a horizontal rather than vertical rolling/locking mechanism. Having recently added some nice old-style German seatbelts to my 1600, they have a release that is straight up +/- 8 degrees. Anything beyond that and they lock, so the mounting point and orientation is critical, and those would absolutely NOT work here.
The angle is 75 degrees, measured at the rear relative to a true horizontal extension.
and
The upper metal bracket is also different between the pre-facelift and post-facelift armrest.
(picture 6 in the PDF manual)
and
and a section also needs to be cut out of the seat cushion
(picture 7 in the PDF manual)
The triangular piece used for redirection can be seen in picture 2 and 5 at the pdf.
.....and the service manual for this
Aha, that service manual is quite helpful, didn’t know that this existed. I know that there has been discussion about the mounting point behind the wooden trim and how secure that point would be to add in a car that didn’t already have it there. At the moment my belt runs through a guide underneath the metal arm of the headrest. From a crash standpoint, it would appear that the triangular guide is merely a redirection of the belt path but doesn’t play a true structural role, since the primary stopping force is the belt locking and it’s other attachment points at latch and side of car. Will decide upon adding this guide, I’m hesitant to drill a hole through my wood unless I know it serves a purpose.
i have an autocad file on the original style arm rest. it maybe posted in pdf form in the FAQ - technical info - https://e9coupe.com/forum/threads/e9-parts-dimensions-drawings-technical-info-and-models.43743/ go to post #6
