Has anyone removed tail light lenses from the chrome frame and successfully reinstalled them into a newer, better, or rechromed frame?
Stan, Peter has the correct method of doing this but I used a heat knife to slice that inner bead away. The heat knife leaves a clear finished edge without the grinding marks from using the dremel tool.
http://www.harborfreight.com/130-watt-heavy-duty-hot-knife-60313.html
Brea, do you have any pictures of the finished result? BTW, I have a few extra lens assemblies -all pitted- and I'll be experimenting. One of the frames has a red directional signal lens instead of amber? I wonder if I could trade with that chap on eBay for his red handled screwdriver?
What I am reading leads me to think that the replacement is simpler than the removal.
I was considering fabricating a lip around the edge to it would attach as it did originally but this seems a superfluous bit of engineering.
I found a manufacturer in Australia who will make the lenses!
Next step is to send samples to him and see how they come out.
Has anyone re-chromed the frame THEN tried to fit the lenses in?
If the tolerance is tight, another step may be warranted
Stan, is the manufacturer in Australia called David Azzopardi Manufacturing at http://www.tailights.com/ ??
This same company also sells them on eBay under the handle name Streetlens.
http://www.ebay.com/csc/streetlens/m.html?LH_Complete=1&_ipg=50&_since=15&_sop=13&_rdc=1
I have purchased a full set from him for my Honda S600 a few years ago.
YES, thats the guy!
What is your opinion of the quality?
