renew and improve door closing and trim parts
deQuincey
Quousque tandem...?
i carried out this little work in some weeks time
it included:
1- lower stainless mouldings disassembly, and cleaning,
2- painting of lower rocker panels in black matt paint
3- remove door retaining lock in body side
4- remove aluminium big panel, clean and install new rubber from w&n, reinstall everything
5- glue some rubber seals that had came-off while disassembly
6- renew bolts to yellow zinc-plated, and install those little rubber white caps that smooth the closing sound
7- reinstall stainless steel mouldings with new stainless steel bolts from w&n
photos will follow soon
disassemble and clean
yeah the original colour was " chamonix white "
clean parts apart and reassembly
just a little advice of how to remove this aluminium trim part from the car:
first of all remove the bolts on the lock retaining piece, there are 3 small bolts and one large
please note that there are two tiny bolts in the top of the part and one more of those in the bottom, (the case of this bottom bolt is that you will remove it in the same moment you disassemble the stainless steel moulding)
remove the intermediate bolt
from those two bolts in the top, the one in the top is needed to disengage the aluminium part from the window rail, so loosen this bolt and carefully rise the window rail a bit until the top of the aluminium part can move out freely
then to remove the part from the car start from the top pull up and frontwards very slowly, you sholud rotate also a bit to get it away from the rubber profile
when you reach the low area, you will need to rotate, pull up and twist the part, always slow and small movements, you´d better do it this way or you will damage something !
intermediate detail of process
painting the lower rocker panel:
renew, polish and new rubber glued to aluminium trim parts:
after assembling the rubber profiles, impact glue is applied on the rear side of the parts, to secure position
aditional work on this topic
two weeks ago was almost impossible to remove the bolts that fixed the lock system in the door side
this was the old status (see top left bolt head damaged)
the reason for change was that the rubber was broken in one side
so, i used a kind of penetrating oil thoroughly over the bolts
and some tools:
first hit the screws with the hammer and chisel, then use the "T" key with a n3 phillips head, and i removed them ok
so this is the aspect of the basis
and these are the old parts
new parts from walloth, note that the new bolts "allen head" type
and asembly
i put some vaseline around the rubber to avoid drying and maintain it fresh
it works ok now
