just in the process of doing some interior elements, i know my car is a bit different i have to renew the lateral panels of the central console
it is essentially a non-AC car but with and odd aftermarket AC that was probably installed in 1974, lateral cuts are not very nice, but it has the advantage of the more beautiful central console área of the non-AC version
this is it:
wanted to renew them in nice new vinyl
the main issue is that the lateral panels are not flat, they have a slight bent in top área, that is the key business of this job.
draw the contours.
so cut the panels:
in order to bend the panel use a file and make a channel
and use a bit of wood
forcé it into the cannel
glue it together for super strong finish
see the angle that you have to achieve
done,a nice solution from the 70-ties
this is it:
draw the contours.
so cut the panels:
