stphers
Hi Markos
It is a 6 X 1.0 on those bolts, If I remember right they are 20 mm long Drilling it out to a 5mm drill bit is not a problem, after all, you are just following the original small hole that you first drilled ( RIGHT IN THE CENTER , OF COURSE ) The problems start when the first drillhole is off centered Then the sh**& t happens
Thanks, Rick
Thanks, Rick
