searching for great floor panels
willybali
Bay Area Ca.
I'm wondering if anyone has found floor pan replacements which cover typical rust or weak areas. Does anyone have replacement ideas for the seat supports (front) I have sheet metal people evaluating the repairs I need and most indicate fabrication best route to follow. Any ideas. All appreciated.
If you check the FAQ, there are suppliers listed with contact info. Some time ago, when I thought I needed much more than I did, I found member Mike Pelly, listed in FAQ, does make floor panels and is not far from you. Good luck.
Walloth and Nesh in Germany are another source of repro body panels (and misc other e3 /e9 parts).
Fairly good ones mostly, though their rear floor panel has bolt holes that are 10mm off.
W&N sells 4 repair panels for the floor, where Mike Pelly's are 2 bigger ones, saving you a bit of work.
