I bought one of these, takes a Fram PH8 spin-on Does it really save time/less mess as opposed to the bottom-bolt filter? Maybe I should just stay with removing- the- filter- assembly- from- the- engine routine I've always done.
Original equipment spin on adapters are still available last I checked.
The M1 used them.
Under 200 bucks
http://www.realoem.com/bmw/enUS/showparts?id=5991-EUR-04-1981-E26-BMW-M1&diagId=11_3226
That way you can use real BMW spin on filters!
Or the Mahle ones for 8 bucks
its only 165.90 bucks from getbmwparts.com ... the downside is that the threaded connector is NLA ... so you would probably have to source that part from belmetricOriginal equipment spin on adapters are still available last I checked.
The M1 used them.
Under 200 bucks
It depends on how frequently you (and whether you or someone else) does the oil service. If it's only once a year, the bottom bolt is tolerable. If you have ready access to a top bolt can, bolt and filter, go that way. I got mine from a 530i abandoned on the side of the road; only have to remember to get the later Big Six readily available filter from the parts supplier.If you gots big bucks and want the spin-on for rapid simple changes, bling value and bragging to your local E9 community, then it's clearly what to do.
I guess some would think Fram falls into the cheapo level (it's only $4-5) but having seen them on several Ferarris, I figured they were good enough for me....I love my spin on adapter, it allows you to use a higher quality filter without worry that it is fitting correctly internally with that spring and metal collar thing. I use a Mobil 1 filter which got the highest reviews from the dudes that cut them all open to compare the innards. Royal Purple one is also good. I wont run a cheapo filter given its importance.
... I got mine from a 530i abandoned on the side of the road; ...
