I have a 72 with AT and Zenith carburetors. here is a description of two problems I have.
Starting: I can start the car with a remote starter. When I remove the remote starter and reconnect the wires the car will not start. The only sound I hear is a "clicking" by the steering column under the left side dash. There are two wires to be connected to the starter ( other than the positive "hot" wire. There is a black/red wire and a second wire , black. There are 3 prongs on the starter (bosch) to which these two wires can be connected. I have tried all possible connections and still nothing other than the clicking sound. I have also tried to wiggle the started switch wires as I turn the key still nothing. It's obviously not he starter as the car will start with the remote. Any ideas or suggestions? I would like to hot wire the starer switch but don't know which wire need to be connected. If I can start the car this way then I'll know it's something internal in the starter switch.
Second problem. When the engine is cold, the choke flaps on both carburetors are closed. When I start the car ( with the remote) both choke flaps open up completely and the car dies. I need to close the choke flap by hand on the front carburetor until the car is warm and then it will stay running, Another alternative is to keep my foot on the gas. Any ideas as to why the choke does not stay closed until the car warms pup and instead open up immediately.
Thanks for any help
Thanks for any help
