This job is easier done on a workbench than in the car however if you are creative enough you can achieve this in the car without undoing the brake lines.
In this case I have already removed the bushing and sent the trailing arms out for powder coating.
You’ll need a bolt or stud. I used a 6” stud 2 nuts and some washers. I doubled up the washers and greased them so they acted like bearings (sort of). You will also need something to push the bushing on the bolt. I purchased an inexpensive Harbor Fright bearing install set. You’ll also need something hollow on one end. A 27mm socket, 12 point works well.
Using the bolt or stud, insert the bolt in the trailing arm and place the small end of the bushing on the flared end of the opening. Be sure to spray lubricant in the trailing arm and the bushing. I used lithium grease since it won’t promote corrosion. Place the nut and washers on the bushing side of the bolt and the bearing tool, washer, and nut on the other end of the opening. Be sure to lube the washers and threads to reduce friction.
In this step I used an electric impact to drive the bushing in to the trailing arm. The white stuff on the bushing is lithium grease.
Once you’ve driven the bushing in to the trailing arm you’ll notice that it didn’t pop out the other side. This is where the 27mm socket comes in handy.
Remove the bearing tool and place the open end of the socket on the hole. The 27mm socket fits on the shoulder of the hole nicely and is large enough to fit the small end of the bushing so that it can now pop through when pressing everything together.
Once you have finished, clean up the grease and start on the next bushing.
It’s always good to take your time. Little tricks like leaving the bushing in the sun for an hour and also greasing the threads on the bolt help make the job easier and also protects the threads so you can reuse the bolt.
Good Luck! I hope this helps!
