I've tried 2 used OE relays. Mine looks like this...
They will both flash all 4 lights when the hazard button is out. They will both flash the correct front and rear lights when the turn signal stalk is moved either right or left.
However, #1 turns the dash indicator light on solid (no blink) as soon as the key is turned on. It stays that way when the turn signal arm is moved and flashing the proper exterior lights or in the neutral position. #2 will blink the dash indicator a couple of times when the turn signal arm is moved then no blink even though the exterior lights are blinking just fine.
I just hate to pay $100-200 for a new OE relay. (It's an E3, not an E9
Has anyone tried the NAPA EL-13 Electronic Flasher Upgrade? It looks like it gets somewhat mixed reviews, but maybe worth $10 to try?
