Hi All. I'm working out some neglected bugs on my coupe during my areas "indoor" season.
73 CSi / Signal Stalk on Right (P/N 1350152 8157)
Problem 1: in either the left or right turn position (natural default), the signals do not stay on past one flash. Manual extra pressure will keep the lights blinking.
Problem 2: Only one initial flash on the dash of the signal indicator (though the emergency flashers successfully alternate between dash and flasher button). I have to listen for the clicking sound of the relay to ensure that I am indicating after that one flash on the dash.
Also - the CSi signal stalk can be set to either left or right when parked and engine off to keep a parking minimal front beam and rear tail light on (common in Europe). This function works perfectly fine.
Anyone else have this issue? Any resolution? I have used contact cleaner on the switch and cleaned it out as best I could. I haven't fully dismantled the unit - frankly, out of fear that it will not go back together again.
Thanks in advance for any insight.
