Which cherry wood used for 1973 CS dashboard?
Weldwood glue: that's bad news. My oldest pieces (veneers and solids) are only 30 years old and are fine. But if 50 years is the lifespan, what other options do we have? Is epoxy the best?
French/European Walnut is stock.
Find a quality local hardwood supplier with a selection of veneers in flat files. Take your time, lots to choose from. Ask what do you want to look at for next 10-20 years? A busy or mellow grain, light or dark...?
I deleted my door ashtrays, don't miss them.
Can someone please identify this type of wood?
depending on the condition of the wood veneer, you can lightly sand the veneer (by hand) to remove the finish. then you can wipe a stain on it and finish it with a satin lacquer. if the veneer is not in good shape - checking / cracking / missing, then you can have everything re-veneered and finished as you like. i used a slightly darker wood with a clear finish. US walnut is generally a little darker than european walnut and is often figured which adds to color definition.
nope, that's a repair the base / re-veneer. you could probably do just the door / side pieces so they match and get the veneer / color close to the dash. in order to remove / replace the dash, the windshield has to come out.
Just about to tackle same...
Want to redo my own wood, too. My '73 is a euro and the veneer on every piece is damaged, at least in part.
My concern isn't in matching the replacement wood with French Walnut; I am more concerned about duplicating the thin veneer and worrying about its longevity. My thoughts are to use a dry, solid walnut, mahogany or even a tigerwood - whatever! Even a burl I find...
Come to think of it: A black walnut chunk arrived on my stream bank last month during a flood, and it looks aged and prepped; stands about three feet high and rough cut at approximately an 8"x8". A gift from the gods; my Triton dash...
So aside from offending the purists (and I'd keep the original flaking thin-veneered pieces in case I got stupid and tried to sell some day), what am I missing concerning solid wood?
The challenge with solid wood, aside from the obvious difficulty in carving it, is that it is likely to warp. Pplywood is much less likely to warp because it has grain running in several directions.
Veneers are usually quite stable, and fairly easy to redo. The challenge I found was in removing the old veneer. It came off the rear wood pieces and the instrument cowl easily, but not so much the doors...
