WTB Starter motor relay for 3.0 CSL
Naito
USA
Hi. I am looking for starter motor relay for my BMW 3.0 CSL.
BMW parts# is 61311352156 and Bosch parts # 0332003014.
I urgently need this item.So I would be great if you could give me any information about it.
Kindest regards naito
sfdon
sfbay area
Naito- you need to use google to find your items....
http://www.ebay.com/itm/Genuine-BMW...y-STARTER-Motor-OEM-61319059177-/201590489209
https://www.fcpeuro.com/products/bmw-relay-starter-motor-61319059177
Used are available everywhere...
Naito
USA
Naito
USA
Hi again Don
thanks for attaching the picture of starter motor relay. I was able to buy the relay at "RogersTii". they have it in stock!
Could you do me a favor?
I am in the middle of replacing to the injector from the carburetor. and I think I have done most of work.
but, I bumped into a problem. I recently purchased OEM ignition distributor at 123.COM. but, I can not figure out How Ignition distributor’s wiring connect to Original wiring from injector. do you know how does it work?
deQuincey
Quousque tandem...?
Hi again Don
dear @Naito ,
i suggest you open a thread for technical discussion on the "general question" or in the "projects and restoration" folders
it will be easier to follow and people will find and respond there
IMHO (take this in between brackets as i do not have an injection car), but i think that distribution has nothing to connect with fuel management, i mean, usually only one cable comes out from the stock distributor and this is the cable that provides the sequential impulse to the coil, it is hooked to the (-) 1 end in the coil, the rest of the cables comming off the distrib cap are the thick black ones going to the top of the coil and to the spark plugs (again, this is in carbed cars, lets see what experts know about injection cars)
i see that your 123 distrib has many cables, so something is different there...
my advise is to open a new thread on this topic in the apropriate folder
regards
bill
stockton, nj
Naito: forgive my ignorance, but is D-Jet fuel injection used in your CSL? If so, the distributor has to have a connection for the "trigger" points which time the FI system. It looks like that might be the connection shown in your pics.
sfdon
sfbay area
Naito- what year CSL do you have?
You will need 3 wires for trigger points
You will need 2 wires for coil
All from distributer
5 wires unless one is shared is a problem because I only see 4 in the picture.
Pre-74 model has a white wire from Ecu to resister block.
Plz post info from 123.com with schematic
sfdon
sfbay area
White to outside 3 pin connector
Yellow to outside 3 pin connector
No connection to center connector
Black to negative of coil
Red to positive of coil
What year? It's important.
Naito
USA
Dear Don
my appologies for delaying my reply as I was out on a business trip.
well, I have connected the wiring according to your instruction. thanks so much. my CSL was manufactured in 1973, so I needed to wiring from ECU to resister block.
and when I start the ignition on fuel pump, ignition distrinutor were working but, when turn starter motor on, engine doesn't start.
and it look like the fuel doesn't come to injector. and I bought the Old stock starter motor relay from american parts supplier named Rogertii. I don't know whether that relay works properly... do you think the problem comes from starter motor relay?
thanks and Best regards Naito
sfdon
sfbay area
You have the single white wire from the distributor to the ECU?
Do you have the red wire connected to the starter motor ?
Naito
USA
Hi again Don
I don't have a white wire from Distributor to ECU...
yes, there is a red wire that is connecting to the starter motor .
I have single white wire but it goes to starter motor relay. that white wire has a number. it is"41". when I checked on wiring diagram, this has to be at starter motor relay...
