My e-brake indicator light kept flashing red. I found the float was half full of brake fluid. The seam must leak so tiny that the fluid will not come out.
Has anyone drilled a small hole in the float to allow the fluid out and found a product that will seal the seam and drilled hole and still allow the piece to float?
Will this new style float work with the original float system? note the 2002 reservoir is the same as the E9 system.
